90-94 ecu posted by 300zxNA2TT on July 28, 2008 at 12:03 PM
the ECU processor runs on. The later cars moved from OBDI to OBDII spec which required a 16 Bit CPU. The 92 will work if it has not been upgraded to use larger injectors than what you have installed.
